I tried the official example, I set the FlattenToSingleFolder to false, but I didn't get the corresponding result.
Pack and Go an Assembly (C#)
This example shows how to get the names of the path and files of an assembly document, add a prefix and suffix to the names, and save the files to a different path using the Pack and Go interface.
// Preconditions:
// 1. Specified assembly exists.
// 2. The folder, c:\temp, exists.
// 3. Open the Immediate window.
// 4. Run the macro.
// Postconditions:
// 1. Prints names of the current path and filenames
// of the assembly documents to Immediate window.
// 2. Prints names of the default path and filenames to which to
// save assembly documents to the Immediate window.
// 3. Specifies the Pack and Go destination folder.
// 4. Specifies that all files get saved to the root directory of the
// Pack and Go destination folder.
// 5. Adds prefix and suffix to user-named filenames.
// 6. Prints names of user-specified path and user-named filenames to
// Immediate window.
// 7. Creates user-named files in user-specified path using Pack and Go.
// 8. Examine c:\temp to verify.
using SolidWorks.Interop.sldworks;
using SolidWorks.Interop.swconst;
using System;
using System.Diagnostics;
using System.Runtime.InteropServices;
namespace PackAndGoCSharp.csproj
partial class SolidWorksMacro
public void Main()
ModelDoc2 swModelDoc = default(ModelDoc2);
ModelDocExtension swModelDocExt = default(ModelDocExtension);
PackAndGo swPackAndGo = default(PackAndGo);
string openFile = null;
bool status = false;
int warnings = 0;
int errors = 0;
int i = 0;
int namesCount = 0;
string myPath = null;
int[] statuses = null;
// Open assembly
openFile = "C:\\Users\\Public\\Documents\\SOLIDWORKS\\SOLIDWORKS 2018\\samples\\tutorial\\advdrawings\\handle.sldasm";
swModelDoc = (ModelDoc2)swApp.OpenDoc6(openFile, (int)swDocumentTypes_e.swDocASSEMBLY, (int)swOpenDocOptions_e.swOpenDocOptions_Silent, "", ref errors, ref warnings);
swModelDocExt = (ModelDocExtension)swModelDoc.Extension;
// Get Pack and Go object
Debug.Print("Pack and Go");
swPackAndGo = (PackAndGo)swModelDocExt.GetPackAndGo();
// Get number of documents in assembly
namesCount = swPackAndGo.GetDocumentNamesCount();
Debug.Print(" Number of model documents: " + namesCount);
// Include any drawings, SOLIDWORKS Simulation results, and SOLIDWORKS Toolbox components
swPackAndGo.IncludeDrawings = true;
Debug.Print(" Include drawings: " + swPackAndGo.IncludeDrawings);
swPackAndGo.IncludeSimulationResults = true;
Debug.Print(" Include SOLIDWORKS Simulation results: " + swPackAndGo.IncludeSimulationResults);
swPackAndGo.IncludeToolboxComponents = true;
Debug.Print(" Include SOLIDWORKS Toolbox components: " + swPackAndGo.IncludeToolboxComponents);
// Get current paths and filenames of the assembly's documents
object fileNames;
object[] pgFileNames = new object[namesCount - 1];
status = swPackAndGo.GetDocumentNames(out fileNames);
pgFileNames = (object[])fileNames;
Debug.Print("");
Debug.Print(" Current path and filenames: ");
if ((pgFileNames != null))
for (i = 0; i <= pgFileNames.GetUpperBound(0); i++)
Debug.Print(" The path and filename is: " + pgFileNames[i]);
// Get current save-to paths and filenames of the assembly's documents
object pgFileStatus;
status = swPackAndGo.GetDocumentSaveToNames(out fileNames, out pgFileStatus);
Debug.Print("");
Debug.Print(" Current default save-to filenames: ");
// Set folder where to save the files
myPath = "C:\\temp\\";
status = swPackAndGo.SetSaveToName(true, myPath);
// Flatten the Pack and Go folder structure; save all files to the root directory
swPackAndGo.FlattenToSingleFolder = true;
// Add a prefix and suffix to the filenames
swPackAndGo.AddPrefix = "SW_";
swPackAndGo.AddSuffix = "_PackAndGo";
// Verify document paths and filenames after adding prefix and suffix
object getFileNames;
object getDocumentStatus;
string[] pgGetFileNames = new string[namesCount - 1];
status = swPackAndGo.GetDocumentSaveToNames(out getFileNames, out getDocumentStatus);
pgGetFileNames = (string[])getFileNames;
Debug.Print("");
Debug.Print(" My Pack and Go path and filenames after adding prefix and suffix: ");
for (i = 0; i <= namesCount - 1; i++)
Debug.Print(" My path and filename is: " + pgGetFileNames[i]);
// Pack and Go
statuses = (int[])swModelDocExt.SavePackAndGo(swPackAndGo);
/// <summary>
/// The SldWorks swApp variable is pre-assigned for you.
/// </summary>
public SldWorks swApp;
