How to disable the option getting latest revision at login
this question is for PDM standard
Thank you, Craig
It's not that option
Each time I login PDM, all latest revisions are automatically downloaded from PDM Vault to the local Vault view. I wan't to turn this option off
Then enable the get version check box underneath "always work with latest".
1) If the file isn't already in your cache, it'll grab the latest version. So you'd have to enable that option I just mentioned.
2) If you had the file open before to a previous version, and have the 'always work with latest' unchecked, it'll pull in the previous version you had open in memory.
Annnnnnnd, due to SPR 859716, how exactly are you navigating to the 'Cache Options'? Make sure you are double clicking the group name or right clicking the group name and selecting 'Open'. If you right click on 'Groups' and select 'Open' and then right click the group name and select 'Properties', the 'Cache Options' page will NOT show the correct information.
actually easier than that - check this tab for your group AND user:
