Get Assembly Mass
Question asked by Luke Frost on Aug 12, 2019
Latest reply on Aug 12, 2019 by Ray McHugh
Good Morning,
I have got the following macro which i have put together based on research from the forums to get the mass of a part and assembly and to write it to a custom property once a simple calculation has been done on the mass.
Option Explicit
Dim cpm As CustomPropertyManager
Public Enum swMassPropertiesStatus_e
swMassPropertiesStatus_OK = 0
swMassPropertiesStatus_UnknownError = 1
swMassPropertiesStatus_NoBody = 2
End Enum
Public Enum swUserPreferenceToggle_e
swUpdateMassPropsDuringSave = 30
End Enum
Dim swModelExt As SldWorks.ModelDocExtension
Dim nStatus As Long
Dim vMassProp As Variant
Set swModel = swApp.ActiveDoc
Set swModelExt = swModel.Extension
vMassProp = swModelExt.GetMassProperties(1, nStatus)
If swModel.GetType = swDocASSEMBLY Or swModel.GetType = swDocPART Then
If Not IsEmpty(vMassProp) Then
Dim strMass As String
If vMassProp(5) < 1000 Then
strMass = Round(vMassProp(5), 0) & "g"
Set cpm = swModel.Extension.CustomPropertyManager("")
cpm.Delete "Weight"
cpm.Add2 "Weight", swCustomInfoText, strMass
MsgBox ("Weight Added")
Else
strMass = Round((vMassProp(5) / 1000), 1) & "kg"
cpm.Delete "Weight"
This is working perfectly for a part and the code does run in an assembly however if i have an assembly who's mass is 62364.07grams the macro is writing 62g to the properties.  When i look at the document properties of the assembly the Mass Unit is set to grams and not kgs. Can someone please help advise where things may be going wrong.
Thanks in advanced
Luke
