Suraj Venkat Pochampally
Meshing Failure Diagnostics
Discussion created by Suraj Venkat Pochampally on Aug 8, 2019
Latest reply on Aug 17, 2019 by Simon Yang
Hello All,
I am currently doing a simulation on an assembly and when I try to mesh all the parts in the assembly (which are of different sizes) the mesh is failing and even after I apply Mesh Controls to all the parts separately, the error is still there.
The part is a bit complex so I'm not sure what to do now.
I have attached the part and the error files below (Note: The part is mated to a 200x200x100 mm Aluminium Plate) .
I would appreciate it if someone can help me out with this.
Thank you!
SolidWorks CorpSolidWorks API Support Mark FischerJason Capriotti
