Update Title Block with API
Question asked by Steve Anderson on Aug 5, 2019
Latest reply on Aug 5, 2019 by Steve Anderson
Update Templates (formats and titleblocks).  This code used to work great in 2017, but in 2017 it just erases the title block altogether.
Someone suggested the new template could not have the same name as the old one.  I did rename it, which made absolutely no difference.
    Private Sub UpdateTitleBlock(ByVal swDraw As ModelDoc2, ByVal _PS As String)
        Dim templatename As String = _PS & " WMI DWG TMPLT.DRWDOT"
        Dim formatname As String = _PS & ".slddrt"
        Dim sTemplate As String = "C:\Sackett-Waconia\Master Documents\SOLIDWORKS TEMPLATES\NewTitleBlocks\" & templatename
        Dim sFormat As String = "C:\Sackett-Waconia\Master Documents\SOLIDWORKS TEMPLATES\NewTitleBlocks\" & formatname
        UpdateTemplate(swDraw, _PS, GetScale1(swDraw), GetScale2(swDraw), sTemplate)
        UpdateTemplate(swDraw, _PS, GetScale1(swDraw), GetScale2(swDraw), sFormat)
    Private Sub UpdateTemplate(ByVal swDraw As ModelDoc2, ByVal _PS As String, ByVal dScale1 As Double, ByVal dScale2 As Double, ByVal sFormatName As String)
        Dim bRet As Boolean ' defines the value to change the drawing format
        Dim swSheetNames As Object = swDraw.GetSheetNames
        Dim bSht As Boolean ' defines sheet
        Dim PaperSize As Integer
        Dim TemplateIn As Integer
        Select Case _PS
            Case "A"
                PaperSize = swDwgPaperSizes_e.swDwgPaperAsize
                TemplateIn = swDwgTemplates_e.swDwgTemplateAsize
            Case "B"
                PaperSize = swDwgPaperSizes_e.swDwgPaperBsize
                TemplateIn = swDwgTemplates_e.swDwgTemplateBsize
            Case "C"
                PaperSize = swDwgPaperSizes_e.swDwgPaperCsize
                TemplateIn = swDwgTemplates_e.swDwgTemplateCsize
            Case "D"
                PaperSize = swDwgPaperSizes_e.swDwgPaperDsize
                TemplateIn = swDwgTemplates_e.swDwgTemplateDsize
        End Select
        For c As Integer = 0 To UBound(swSheetNames)
            bSht = swDraw.ActivateSheet(swSheetNames(c))
            SWSHEET = swDraw.GetCurrentSheet
            If (SWSHEET.IsLoaded) Then
                bRet = swDraw.SetupSheet4(SWSHEET.GetName.ToString, PaperSize, TemplateIn, dScale1, dScale2, False, sFormatName, 0.0#, 0.0#, "")
                SWSHEET.SetTemplateName(sFormatName)
                swDraw.Rebuild(c)
                swDraw.ForceRebuild3(True)
        Next
        ' Return to Sheet1
        bSht = swDraw.ActivateSheet(swSheetNames(0))
Thank you!
