zafercan dedeoglu
simplified shell model does not show same results as solid model
Discussion created by zafercan dedeoglu on Aug 4, 2019
Latest reply on Aug 6, 2019 by zafercan dedeoglu
From the full solid model I made a symmetry constraint, so that I ended up with half of the solid model. The results is the same for these two (same meshsize). But when I simplify the model further with a part of the model made with shell elements, I end up with results that dont match anymore (VM, P1, P3). This new model with shell elements (2 mm thickness - midsurface) has a symmetry constraint and shows no sign of rotation over the plane of symmetry.
There is a pressure load on the inside of the cylinder and the whole model is influenced by gravity. Foundation bolts are used as fixation.
