Hello;
For some reason what I've done for this in the past doesn't seem to be working. These were some notes of what I've done in the past, but it doesn't seem to be working. I'm trying to assign individual colors to various configs.
- Go into your configuration, & r.c. & go to properties. Make sure the use configuration specific color is checked, & it’s there if you click the color tab you can specify your desired color, including define custom colors, which allows for the number entries etc.
- Next, go into the display states which is right below the configurations, & r.c. them or one if it’s only one showing, & chose properties, then select link display states to configurations.
Am I forgetting something?
Thks in advance for any input;
Rob_D SW 2018 sp5
Hello;
I found out what was going on. This was best resolved in the fan out section in the right of the design tree. In the appearance column there were appearances overriding the body colors. I r.c. the appearance & selected remove all part appearances, & then was able to utilize the two points from my above post question. It was easier also to manipulate the colors & display states from that section in the right of the design tree. Then the conf./ display states properties were able to be used etc.
Regards;
Rob_D
