I'm trying to run a .sts script on a few thousand .stl files using #TASK. But it reports the error:
Generic error: This indicates that #TASK failed to run a macro. Please make sure that you can run macros in SolidWorks
I've run the same macro on Solidworks which works absolutely fine. I'm attaching the .sts script below:
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set Part = swApp.ActiveDoc
Dim myModelView As Object
Set myModelView = Part.ActiveView
myModelView.FrameState = swWindowState_e.swWindowMaximized
Part.ViewDisplayHiddengreyed
' Named View
Part.ShowNamedView2 "*Front", 1
Part.ViewZoomtofit2
' Save As
longstatus = Part.SaveAs3("%FOLDER1%\" & Part.GetTitle() & ".JPG", 0, 0)
' Named View
Part.ShowNamedView2 "*Top", 5
Part.ViewZoomtofit2
' Save As
longstatus = Part.SaveAs3("%FOLDER2%\" & Part.GetTitle() & ".JPG", 0, 0)
' Named View
Part.ShowNamedView2 "*Right", 4
Part.ViewZoomtofit2
' Save As
longstatus = Part.SaveAs3("%FOLDER3%\" & Part.GetTitle() & ".JPG", 0, 0)
swApp.CloseDoc Part.GetTitle
Set Part = Nothing
Hi Dheeraj,
Please see the attached document for the advanced troubleshooting for #TASK scripts. Please send me the generated text file and I will see why it is not working:
Artem
