Have anyone ever specified the Material to be used during the welding process of sheet metal parts? My drawing specified the base material to be welded (Similar material) for all parts.
I know we specify the weld type, Size, Spacing, grinding after weld etc. but never the welding material. I've always assumed that the material used for the welding will always be the same material as the base parts. If anyone can point me where the material to be used is specified in any standard, that would be really appreciated. Thanks in advance for any help.
The standard will be governed by what you are welding and for what application. I'm not a CWI and I'm sure there is someone here that knows more about it but I have a little exposure to welding.
MIG? TIG? FCAW?
Do you know the base material properties? Thickness? The type of weld for that joint configuration? What position the parts will be welded in?
Without knowing any specifics I'm guessing they'll probably use some E70 wire. I would check with the shop foreman or welder if they're experienced with welding to code. If not, the guy that writes your company's welding procedures should be able to give you more information.
