Hello everybody,
After rendering, some parts are not solid, you can look through them, in the included image I show an example of the problem.
Has anyone a solution for this?
Best regards,
Michiel
Hello everybody,
Best regards,
Michiel
Thanks for your fast reply, I am running an accurate render. Do you mean to change the material in Solidworks on part level or in Visualize? Because on part level they al have AISI 304 (metal) as material. I checked it in Visualize and there also the appearence is a metal one.
Best regards,
Michiel
Michiel Trappeniers - Yes I meant the Part Level... Check the part by editing the Appearance, check the advanced tab and check the transparency settings..
Looks like you have overlapping parts... which are z-fighting.
Use part selection mode and hide/show the parts in that area.
Michiel Trappeniers Check the Part Material selected, looks like Glass or Air is selected as the Material.
