Help with this assembly to DXF macro
Question asked by Brock Talley on Jul 25, 2019
Sorry in advance if this question has been beat to death. I actually got this macro from the forum and it works great I just would like to edit it to make it easier for what I do. I'll post the macro below this explanation.
So it takes the assembly opens up the part and exports it as a DXF with bendlines which is exactly what I need but I would like the option of being able to select which folder it saves too I'd appreciate any help with this thank you in advance.
   Dim swApp                       As SldWorks.SldWorks
   Dim swModel                     As SldWorks.ModelDoc2
   Dim swAssy                      As SldWorks.AssemblyDoc
   Dim swConf                      As SldWorks.Configuration
   Dim swRootComp                  As SldWorks.Component2
   Dim nStart                      As Single
   Dim bRet                        As Boolean
   Set swModel = swApp.ActiveDoc
   Set swConf = swModel.GetActiveConfiguration
   Set swRootComp = swConf.GetRootComponent3(True)
   Debug.Print "File = " & swModel.GetPathName
   TraverseComponent swRootComp, 1
   Debug.Print "Finished!"
Sub TraverseComponent(swComp As SldWorks.Component2, nLevel As Long)
Dim vChildComp                  As Variant
   Dim swpart                      As SldWorks.PartDoc
   Dim swChildComp                 As SldWorks.Component2
   Dim swConfig                    As SldWorks.Configuration
   Dim swConfMgr                   As SldWorks.ConfigurationManager
   Dim swChildModel                As SldWorks.ModelDoc2
   Dim swOpenModel                 As SldWorks.ModelDoc2
   Dim swChildCustPropMngr         As CustomPropertyManager
   Dim swChildModelDocExt          As ModelDocExtension
   Dim swsheetmetal                As SldWorks.SheetMetalFeatureData
   Dim swFeat                      As SldWorks.Feature
   Dim swBody                      As SldWorks.Body2
   Dim Sheet_metal                 As Boolean
   Dim Boolstatus                  As Boolean
   Dim Thickness                   As Double
   Dim conv                        As Double
   Dim i                           As Long
   Dim loptions                    As Long
   Dim lerrors                     As Long
   Dim sPadStr                     As String
   Dim FilePath                    As String
   Dim FileName                    As String
   Dim swThkDir                    As String
   Dim swMatDir                    As String
   Dim swCurrent                   As String
   Dim RefCfg                      As String
   Dim ChildConfigName             As String
   Dim sMatName                    As String
   Dim sMatDB                      As String
   Dim exFileName                  As String
   Dim Bodies                      As Variant
   vChildComp = swComp.GetChildren
   For i = 0 To UBound(vChildComp)
       Set swChildComp = vChildComp(i)
       'Check to see if current component is suppressed
       If swChildComp.IsSuppressed = False Then GoTo Active Else GoTo Skip
Active:
Set swChildModel = swChildComp.GetModelDoc2
   'Check to see if child component is an Assembly or part
   If (swChildModel.GetType <> swDocPART) Then GoTo Jump 'Skips Subassemby level
Set swpart = swChildModel 'Applies part commands for current component
FilePath = Left(swComp.GetPathName, InStrRev(swComp.GetPathName, "\") - 1)
FileName = swChildModel.GetTitle 'Get title of component
swCurrent = swChildComp.ReferencedConfiguration 'Get current configuration of component
Bodies = swpart.GetBodies2(swBodyType_e.swAllBodies, True)
Set swBody = Bodies(0)
   If swBody.IsSheetMetal = 0 Then 'If Body is not sheet metal
       'Debug.Print "Component " & FileName & " is not a sheet metal component"
       'Debug.Print "Current Config is : "; swCurrent
           GoTo Jump
   If swBody.IsSheetMetal = 1 Then 'If body is sheet metal
       Debug.Print "Processing component " & FileName & " as a sheet metal component"
       GoTo Process
Process:
'Get Part Material
sMatName = swpart.GetMaterialPropertyName2(swCurrent, sMatDB)
If sMatName = "" Then sMatName = "None"
Debug.Print "    Current material is : "; sMatName
'Get part Thickness
Set swFeat = swChildModel.FirstFeature
   While Not swFeat Is Nothing
   If swFeat.GetTypeName = "SheetMetal" Then
       Set swsheetmetal = swFeat.GetDefinition
       Thickness = swsheetmetal.Thickness
       conv = 39.3700787401575
       Thickness = Thickness * conv
Debug.Print "    Thickness is :"; Thickness; "inches"
Set swFeat = swFeat.GetNextFeature
   Wend
swMatDir = FilePath & "\" & sMatName
Debug.Print swMatDir
If Dir(swMatDir, vbDirectory) = "" Then MkDir swMatDir
swThkDir = FilePath & "\" & sMatName & "\" & Thickness
Debug.Print swThkDir
If Dir(swThkDir, vbDirectory) = "" Then MkDir swThkDir
exFileName = FilePath & "\" & sMatName & "\" & Thickness & "\" & FileName & "-" & swCurrent
Debug.Print exFileName
Set swOpenModel = swApp.ActivateDoc3(swChildModel.GetPathName, True, loptions, lerrors)
Boolstatus = swChildModel.ShowConfiguration2(swCurrent)
swChildModel.ExportFlatPatternView exFileName & ".DXF", 0
swApp.CloseDoc (swChildModel.GetPathName)
GoTo Jump
Skip:
   Debug.Print "Skipped"
Jump:
       TraverseComponent swChildComp, nLevel + 1
          Next i
