I would like to fill MATERIAL in my cut list, starting from tab builder (I have a xls file with materials in one tab). The link with the excel file storing the material seem to be broken so no way to make selections. When I type, in the material field the material this is not retained in my cut list and not either in cut list summary, also. Whats is wrong not doing well?
After this I tried to start from cut list summary entering the material, but doesn't retain the material as well.
For description field in tb, I don't need to put nothing because is good for me to replace with cut list name. (have to eliminate DESCRIPTION from tb)
my tab builder is saved as a weldment, see this
this is my cut list, very simple but missing the materials and getting rid off by default description containing PLATE .....
Please what do I have to do? Do I have to create a new library with materials ?. Really I would like to continue using my excel file with all of theses materials because is easier.
thanks in advance
Dan, have a nice summer but waiting for you
I believe the Property Tab Builder only applies to File> Properties & Config Specific properties.
I don't believe you can apply to bodies.
