Hi All,
Is there a way that the Plate item (shown below item 1 and 2) is described with thickness only? For example, I only want Plate, 10mm to be in the evaluated value. I know I can modify/delete the value, but I want to have this automatically so that I do not have to edit the description of each body everytime.
Also, how can I have the PLATE in small caps?
LS
You'll need to open the .sldlfp files used to create the Structural Member bodies and make your changes there (re-type "plate" however you want it and delete the unwanted linked text). This will only affect new Parts using the profile since Parts don't maintain a link to the .sldlfp files, but just copy the sketch into the feature.
