Hi, I am trying to use the boundary boss/base feature to model a weld-like feature (it has to be modeled in this way to ensure a good throat thickness). I have modeled several similar joints without problems but for some reason for this specific joint I cannot get the boundary boss/base feature to merge with the rest of the bodies.
I am using the exact same technique that I've been using for all my other joints. Does anyone see where the problem is and how I might be able to solve this?
I have attached the .SLDPRT file in question. The last feature is the boundary boss/base where I have unchecked the 'merge result' box, but it should merge obviously. Whenever it just shows 'Failed to merge the newly generated body with the workpiece'. Any ideas?
Thank you,
Kris
For some reason, it isn't liking your use of curves and the choice of dimensions. I replaced the curves with split lines and it merged.
