John Riggs
'Save As' to initiate a macro
Discussion created by John Riggs on Jul 15, 2019
Latest reply on Jul 15, 2019 by John Riggs
Hello All,
I'm attempting to have a macro be initiated by saving a drawing. I've done some research and found a forum of how to do it in excel but with my extremely limited macro knowledge, I am unable to convert the code to work in Solidworks.
The code for excel I found is:
Private Sub Workbook_BeforeSave(ByVal SaveAsUI As Boolean, Cancel As Boolean) For x = 1 To Sheets.Count If Worksheets(x).Range("A1").Value <> "" Then Sheets(x).Name = Worksheets(x).Range("A1").Value End If Next
Below is the macro that I already have.
Any help or direction would be greatly appreciated.
Thanks!
Dim swdoc As SldWorks.ModelDoc2
Dim swView As SldWorks.View
Dim swAnn As SldWorks.Annotation
Dim vSheetNames As Variant
Dim vSheetName As Variant
Dim vAnns As Variant
Dim vAnn As Variant
Dim swWeldSymbol As SldWorks.WeldSymbol
Dim BottomSymbolName As String
Dim topfinishingName As String
Dim bottomfinishingmethod As String
Dim TopSymbolName As String
Dim DisplayWarning As Boolean
Set swModel = swApp.ActiveDoc
Set swDraw = swModel
vSheetNames = swDraw.GetSheetNames
For Each vSheetName In vSheetNames
swDraw.ActivateSheet vSheetName
Set swView = swDraw.GetFirstView
While Not swView Is Nothing
vAnns = swView.GetAnnotations
If Not IsEmpty(vAnns) Then
For Each vAnn In vAnns
Set swAnn = vAnn
If swAnn.GetType = swAnnotationType_e.swWeldSymbol Then
Set swWeldSymbol = swAnn.GetSpecificAnnotation
BottomSymbolName = swWeldSymbol.GetText(swWeldSymbolTextTypes_e.swWeldSymbolTextBelow)
TopSymbolName = swWeldSymbol.GetText(swWeldSymbolTextTypes_e.swWeldStaggerTextAbove)
If TopSymbolName <> "" Then Debug.Print " Symbol name above: " & TopSymbolName
If BottomSymbolName <> "" Then Debug.Print " Symbol name below: " & BottomSymbolName
If BottomSymbolName = "<AWLD-GSQ>" Or TopSymbolName = "<AWLD-GSQ>" Or BottomSymbolName = "<AWLD-PLUG>" Or TopSymbolName = "<AWLD-PLUG>" Then
swAnn.Select3 bottomfinishingmethod = "g-grinding", Nothing
swDraw.ViewZoomToSelection
DisplayWarning = True
Next
Set swView = swView.GetNextView
Wend
Next
If DisplayWarning Then MsgBox ("CAUTION: Add Grinding or Confirm weld thickness WILL NOT damage adjoining surface!")
