The standard sheet format line weights are too light when they print. How can I increase the line weights and have them retained in the default sheet formats.
Hi Joseph,
further to Kevin Chandler's fine advise. Once you update the sheet format you can use https://cloud.centralinnovation.com.au/WebSharpSwTask to update your existing drawings to the new sheet format if required.
Make the changes in your drawing template and save your new sheet format file, too.
See Mr. Schroeder's FAQ: What's the difference between a sheet format and drawing template? as it may offer some further insight.
Kevin
