Hi, I've been working on my fuel tank for a while and I have it how I want it to be, however I have some problems that I am not understanding the reason why I am having problems.
I am concerned about symmetry, even though I have taken care to make sure everything is symmetrical by using the mirror tool where I can in my sketches, when I introduce a fillet it seems there is a small problem on the right back edge of the tank. When I look for the Symmetry Check tool, it is not available to me and I am not sure why.
Another way I could check symmetry would be to flatten parts and check them that way but I am unable to flatten any parts either.
I would appreciate any help please.
Thanks, Daniel.
Theres actually a problem on both of the back edges, you'll see if you zoom in closer.
Roll back to before the fillets, Knit the two planar bottom faces to the upper part, add your fillet. Afterwards if you wanna keep the bottom faces separate from the top part, make an Offset face of them with 0mm offset, and delete the knit faces.
This way the fillet came out fine in my testing, don't know what causes the problem though.
Edit: Sketch 2 isn't symmetric, you have two different radii, which makes it impossible to have a tangent relation to the bottom arc.
