I understand it should warn you, but every damn time you open the file???
I assume no one can answer as there are multiple versions of this question out there...
Well here's another...
Boy do i miss Inventor...
John
John
Are you using DFS?
"Distributed File System (DFS) is not currently tested or supported for SOLIDWORKS® products, and thus not recommend in such an environment.
By not being tested we do not guarantee that our software will run with no issues; however if customer insists to use it in DFS, it should be thoroughly tested prior implementation."
Were any files re-named or moved?
