These are the top 20 most accessed SOLIDWORKS® Knowledge Base solutions during the second quarter of 2019. It is a good idea to review these solutions to determine if any of them apply for your business.
Rank | Solution ID | Question | |
1 | S-076063 | Is there a SolidPractice available on the topic of “Best Practices for Managing Large Assemblies”? | |
2 | S-076254 | Is there a SolidPractice available on the topic of “SOLIDWORKS® Upgrades"? | |
3 | S-076233 | Is there a SolidPractice available on the topic of SOLIDWORKS PDM Professional Architecture? | |
4 | S-076224 | Is there a SolidPractice document on the topic of searching in SOLIDWORKS® PDM? | |
5 | S-069274 | Is there a tool for SOLIDWORKS® PDM that can help verify connectivity between a client and server or between replicated servers to ensure the server and service ports are accessible? | |
6 | S-076242 | Is there a SolidPractice available on the topic of “Bolt Connectors Technical Definition, Tips and Tricks”? | |
7 | S-076283 | Is there a SolidPractice available on the topic of “Installation of SOLIDWORKS Electrical”? | |
8 | S-017826 | How can you restore a copy of a SOLIDWORKS® PDM file vault to a separate system from a SQL database backup (.bak) in order to test upgrades or troubleshoot vault specific problems? | |
9 | S-039210 | What could cause a SOLIDWORKS® PDM client connection to an archive server over a WAN or VPN connection to fail with error 'The socket was closed gracefully on the other end' or ‘The Archive Server connection receive operation timed out'? | |
10 | S-076341 | Is there a SolidPractice available on the topic of "SOLIDWORKS Data Import and Composer Update Functionality"? | |
11 | S-021323 | What could be the reason for a SOLIDWORKS® PDM client workstation to fail logging into a file vault where the file vault database is hosted on a SQL Server named instance (<SERVERNAME>\<INSTANCENAME>)? | |
12 | S-020198 | What does the message "No database connected to this view" mean when browsing into a SOLIDWORKS® Enterprise PDM file vault view? | |
13 | S-076235 |
14 | S-034751 | What could cause the error 'Archive server could not open windows registry' when creating a local view or attaching to an archive server from a SOLIDWORKS® PDM client? | |
15 | S-032108 | What could be a reason for the error 'Windows Sockets error '#10054: Connection reset by peer.' seen in a SOLIDWORKS® Enterprise PDM log file? | |
16 | S-076289 | Is there a SolidPractice available on the topic of Thermal Management using Electronics Cooling Module? | |
17 | S-012984 | How is a local SOLIDWORKS® Enterprise PDM file vault view manually removed / deleted? | |
18 | S-038121 | Is there a tool for copying only selected file archives (partial copy) from a SOLIDWORKS® PDM file vault archive for testing purposes? | |
19 | S-033644 | Using the SOLIDWORKS® Enterprise Administration tool or View Setup wizard, what can cause ‘Could not initialize archive server connection. Error Description: The system detected a possible attempt to compromise security.' when attaching to archive server? | |
20 | S-08640 | How do you rename a SOLIDWORKS® PDM file vault? |
Thank you for the Knowledge Base summary.
I learned a new SW term "SolidPractice" and it appears from your post, that these are numerous and regular type of SW document.
That typed, I don't see a link to these on my MySolidWorks home page.
Perhaps, a to do for someone's list of to-do's would be to add such a link would help propagate this wisdom.
Also, searching MySolidWorks for "SolidPractice" yields over 1,300 hits, none of which are a "SolidPractice".
Thank you again,
Kevin
