Matthew Nann
SOLVED : Motion Study Results Exporting to CVS file
Discussion created by Matthew Nann on Jul 9, 2019
Latest reply on Jul 10, 2019 by Matthew Nann
macro helpsae
Hi, I am a part of Clemson BAJA SAE. I am designing a rear suspension and I need to analyze graphs like camber gain and wheel paths. Thus I want to export the result plots to a CVS file with a macro. I can not do this by hand since my plan is to run an algorithm that continues to update and improve the suspension design based on the results of the motion study.
boolstatus = swCosmosMotionStudyResults.ExportCSVFile(plotFeatures(2), "C:\Users\Matt\Desktop\Baja 2019-2020\Programming_For_Design\Trace Path1.csv")
All I need is for this line to work. It does not throw an error, but it does not export the file. I believe I correctly got the plot features because the size of the array is 3. However, when accessing GetTypeName I get this run time error. This makes me scratch my head because a type mismatch error was not thrown when initializing plotFeatures as an IFeature object and GetTypeName is a method of the IFeature object, which makes me think plotFeatures is corrupted in some way.
Thank you for any help!!
   Debug.Print String(255, vbNewLine)
   Dim swModelDocExt As SldWorks.ModelDocExtension
   Dim swMotionMgr As SwMotionStudy.MotionStudyManager
   Dim swMotionStudy1 As SwMotionStudy.MotionStudy
   Dim swResults As SwMotionStudy.MotionStudyResults
   Dim swMotionStudyProps As SwMotionStudy.MotionStudyProperties
   Dim swCosmosMotionStudyProps As SwMotionStudy.CosmosMotionStudyProperties
   Dim swCosmosMotionStudyResults As ICosmosMotionStudyResults
   Dim boolstatus As Boolean
   Dim swSelMgr As SelectionMgr
   Set swModel = swApp.ActiveDoc
   Set swModelDocExt = swModel.Extension
   Set swMotionMgr = swModelDocExt.GetMotionStudyManager()
     If (swMotionMgr Is Nothing) Then
      End
   Dim CWAddinCallBackObj As Object
   Set CWAddinCallBackObj = swApp.GetAddInObject("CosmosWorks.CosmosWorks")
   Set COSMOSWORKSObj = CWAddinCallBackObj.COSMOSWORKS
   Set swMotionStudy1 = swMotionMgr.GetMotionStudy("PhysSim")
   If (swMotionStudy1 Is Nothing) Then
      MsgBox "PhysSim is not available."
      End
   swMotionStudy1.StudyType = 4
   If Not swMotionStudy1.IsActive Then
      swMotionStudy1.Activate
   Set swMotionStudyProps = swMotionStudy1.GetProperties(4)
   Set swCosmosMotionStudyProps = swMotionStudyProps
   Set swCosmosMotionStudyResults = swMotionStudy1.GetResults(4)
   Call swMotionStudy1.Calculate
   Dim numPlots As Integer
   numPlots = swCosmosMotionStudyResults.GetPlotCount()
   Debug.Print " Number of plots: " & swCosmosMotionStudyResults.GetPlotCount
   Dim plotFeatures() As IFeature
   plotFeatures = swCosmosMotionStudyResults.GetPlotFeatures()
   Dim featName As String, featType As String
   If Not (plotFeatures(0) Is Nothing) Then
      Debug.Print "Number of elements in plotFeatures: " & UBound(plotFeatures, 1) - LBound(plotFeatures, 1) + 1
      boolstatus = swCosmosMotionStudyResults.ExportCSVFile(plotFeatures(0), "C:\Users\Matt\Desktop\Baja 2019-2020\Programming_For_Design\Trace Path1.csv")
      Debug.Print "it worked: " & boolstatus
      featType = plotFeatures(0).GetTypeName()
      Debug.Print featType
   Else
      Debug.Print "No plots"
SOLVED
I pretty much figured it out with a little workaround, but still, the method achieves all my goals. For some reason, only actual plots that have X-values and Y-Values can be used in the ExportCSVFile(...) function. Thus to achieve a CVS file with the wheel trace path. I added three linear displacement result plots to the same plot (Plot6). The full file path is needed including the new file name. This macro can run even with the plots hidden, thus can be used iteratively in my new genetic algorithm.
End
End
If Not swMotionStudy1.IsActive Then swMotionStudy1.Activate
Dim plotFeatures() As IMotionPlotFeatureData
featType = plotFeatures(2).GetTypeName()
'PLOT FEATURE MUST BE AN ACTUAL PLOT, EXPORTING TRACE PATHS DID NOT WORK ==> Angular Displacement, Linear Displacement, and Etc can work
boolstatus = swCosmosMotionStudyResults.ExportCSVFile(plotFeatures(4), "C:\Users\Matt\Desktop\Baja 2019-2020\Rear Suspension\Anything.csv")
