I am in the long and tedious process of creating a viable Routing Library with Swagelok parts. I do a couple dozen or so a day adding the custom property info I will want and the Connection Points and Routing Points. I also throw in a Mate Reference for those who may not use the part in Routing so it behaves like a Toolbox component.
I then save the part and change the properties to READ ONLY within the Windows File Folder to prevent users from over-writing anything. Our silly company still refuses to move to PDM.
What I have discovered is that when I go back, some, not all, grey out (SUPPRESS) the mate ref and all the Routing points....automatically. This is some error/bug I have not seen before and I am curious if there is an issue not saving the route before creating the mate reference, or some other CLICK+CLICK order that needs addressing. Or any workaround someone might know of that solves this. I do not want to create hundreds of Library files only to have 1 in 10 suppress the routing info so when you're in the Route you discover the fitting you want won't add correctly.
Insight appreciated!
File Attached
