I started to learn API, It will be great help if someone solve this issue.
Making a macro for "Pack & Go" Assembly with parts and drawings, I used below code that I found on internet it works to pack & go files with same name and 1st letter lower case.
Requirement
1) 1st Letter should be Upper case (or no change in name style)
2) Assembly, Parts and drawings have same format and that is for example as below (important for pack and go : 1234567-8 Rev.1)
"PART ASSEMBLY 1234567-8 Rev.1.SLDASM",
"PART ASSEMBLY 1234567-8 Rev.1.SLDDRW"
"PART-1 1234567-8 Rev.1.SLDPRT"
"XYZ-2 1234567-8 Rev.1.SLDPRT"
"ABC 1234567-8 Rev.1.SLDPRT"
so user form should have 3 different entry for this, 1st for 7 digit number that is order number(1234567), 2nd for sub section number(8) and last is for revision.
3) we have same custom property in assembly and parts that need to be link with pack & go
- Number : "1234567"
-Sub section : 8
- Revision - Rev.1
Const strOutputPath As String = "C:\Users\PC\Downloads\test\"
Dim swPackAndGo As SldWorks.PackAndGo
Dim intDocCount As Integer
Dim vPathNames As Variant
Dim strSetPathNames() As String
Dim i As Integer
Dim vStatus As Variant
Set swModel = swApp.ActiveDoc
If swModel Is Nothing Then
swApp.SendMsgToUser "Please open an assembly or drawing."
Exit Sub
ElseIf swModel.GetType <> swDocASSEMBLY And swModel.GetType <> swDocDRAWING Then
Exit Sub
Set swPackAndGo = swModel.Extension.GetPackAndGo
intDocCount = swPackAndGo.GetDocumentNamesCount
ReDim strSetPathNames(intDocCount - 1) As String
swPackAndGo.GetDocumentNames vPathNames
swPackAndGo.SetSaveToName True, strOutputPath
swPackAndGo.IncludeDrawings = True
vStatus = swModel.Extension.SavePackAndGo(swPackAndGo)
Warm Regards.
Are you willing to pay for this macro as I've limited time to do this macro on pro bono?
