Hello everyone, I've been trying to model aerofoil with serrations; a leading edge with sinusoidal serration and trailing edge with saw tooth serration.
I have tried to model the L.E model and would like to have your opinions about the rightness of the steps used and how can I improvise it. I've mentioned a brief description of the aim to be achieved and steps.
Aim: The aim is to test a NACA 0012 aerofoil with L.E and T.E serrations for its aerodynamic performance. Aerodynamic parameters will be analysed and compared at several angles of attack at a fixed velocity but with different number of serrations.
Steps:
1. Front Plane - Curve through xyz(imported naca0012 co-ordinates) - convert entities - closed T.E (extend T.E + trim)
2. Copied the same onto another plane at 0.50m dist apart
3. 3D sketch - equation driven curve between both planes to generate sinusoidal profile.
4. Lofted Boss/Base - Profile : sketch on both planes
Guide Curve : sinusoidal spline
Guide curve influence type : "To next sharp"
THANK YOU!
