I have this part file with multiple configurations. I would like to export the flatten surfaces to dxf.
When I run the macro, iterating through the configurations, it changes the model. It gets the flatten surface of the first configuration and applies to all others configurations.
If I change the configuration manually and execute the instruction to export (ExportToDWG2), it works perfectly.
Note: For test purposes, only the "N-0003" configuration has a flatten surface.
Option Explicit
Dim bRet As Boolean
Dim vConfNameArr As Variant
Dim sConfigName As String
Dim nStart As Single
Dim i As Long
Dim bShowConfig As Boolean
Dim bRebuild As Boolean
Set swModel = swApp.ActiveDoc
vConfNameArr = swModel.GetConfigurationNames
For i = 0 To UBound(vConfNameArr)
sConfigName = vConfNameArr(i)
bShowConfig = swModel.ShowConfiguration2(sConfigName)
bRebuild = swModel.ForceRebuild3(False)
Export2DXF
Next i
Sub Export2DXF()
Dim FilePath As String
Dim PathSize As Long
Dim PathNoExtension As String
Dim NewFilePath As String
Dim dataAlignment(11) As Double
Dim varAlignment As Variant
Dim swPart As PartDoc
dataAlignment(0) = 0#
dataAlignment(1) = 0#
dataAlignment(2) = 0#
dataAlignment(3) = 1#
dataAlignment(4) = 0#
dataAlignment(5) = 0#
dataAlignment(6) = 0#
dataAlignment(7) = 1#
dataAlignment(8) = 0#
dataAlignment(9) = 0#
dataAlignment(10) = 0#
dataAlignment(11) = 1#
varAlignment = dataAlignment
Set swPart = swModel
FilePath = swModel.GetPathName
PathSize = Strings.Len(FilePath)
PathNoExtension = Strings.Left(FilePath, PathSize - 6)
NewFilePath = PathNoExtension + sConfigName & ".DXF"
'Exportar Padrão Planificado
options = 1
bRet = swPart.ExportToDWG2(NewFilePath, FilePath, swExportToDWG_ExportSheetMetal, True, varAlignment, False, False, options, Null)
Edit: Behaviour description and title correction.
