Visualize lists the models in the order I import them but I do not seem to be able to change the order. I would expect to be able to drag and drop the models into an alternative order but that doesn't seem to be possible. Have I missed something?
This is not yet possible in Visualize, but it is on our list. We have it prioritized accordingly and the more times customers request it, the higher it can move up the list. I'm not sure if this specific feature is properly added by a customer as an Enhancement Request in the SOLIDWORKS Customer Portal. If it is - then up vote it. If it's not, then someone please create it and then send the link on this Viz forum thread for others to up vote.
That's the best way to move up features in the Viz team's list! Thanks all.
Brian Muhlbach for his visibility on this request.
If I only have a few models, I'll delete and undo. That model will go to the bottom. If you plan it right you can get the order you want. It's silly, but it works
David McNeill - good question for Brian Hillner
