I'm having quite poor performance on my Dell 5530 running SW 2019 SP.03
its running the following config see bellow:
What is notice with Solidworks is that my onboard UHD 630 is also used when running SW.
My quadro P2000 never sees any proper use.
I've already tried other quadro drivers (running certified 430.64), making sure a SW profile is enabled and selected the high performance Quadro as my main.
Still no luck. I see quite high temps on my CPU and GPU, I suspect because its not using the Quadro to its full benefit.
Hope you guys can help me trouble shoot this.
Also see att. screenshots.
Computer: DELL Precision 5530 CPU: Intel Core i7-8850H (Coffee Lake-H, U0) 2600 MHz (26.00x100.0) @ 898 MHz (9.00x99.8) Motherboard: DELL 0N0DK2 BIOS: 1.10.1, 04/26/2019 Chipset: Intel CM246 (Cannon Lake-H) Memory: 16384 MBytes @ 1330 MHz, 19-19-19-43 - 16384 MB PC21300 DDR4 SDRAM - SK Hynix HMA82GS6JJR8N-VK Graphics: Intel UHD Graphics 630 (Coffee Lake-H GT2) - Integrated Graphics Controller [DELL] Intel UHD Graphics 630, 1024 MB Graphics: NVIDIA Quadro P2000 (GP107GL) [DELL] NVIDIA Quadro P2000, 4096 MB GDDR5 SDRAM Drive: KXG60ZNV512G NVMe TOSHIBA 512GB, 500.1 GB, NVMe Sound: Intel Cannon Lake-H/S - cAVS (Audio, Voice, Speech) [B0] Network: Intel 9260NGW Wireless-AC Wireless Network Adapter Network: DisplayLink Network Adapter NCM OS: Microsoft Windows 10 Enterprise (x64) Build 17763.557 (1809/RS5)
Hi. It might be worth telling us what you mean by slow as that term is super vague. Is it "slow" rotating a single simple part, or a 10,000+ assembly.
You CPU speed is a bit slow at 2.6Ghz as SW recommends 3.0Ghz as a minimum. in one of your screenshots of task manager it shows the CPU at 3.87Ghz meaning this is probably a boost speed which is why your CPU temp is high like you mentioned.
You also mentioned your GPU temp was high even though your said you GPU usage was low. If your GPU is normally hot with little load or while idea that could be a separate issue
You could also try disabling your onboard graphics, to force your PC to use your GPU all the time.
If still slow I would check your SOLIDWORKS setting if you have a large/complex assembly. Try turning on the enhanced graphics pipeline feature in your setting as well
