Hi!
I am designing a piping system. how can I draw a hollow circular section 3D Tee, with fillets, such as in the stetch below?
I am using Solidworks 2018.
Thanks in advance,
Best regards,
AndradeSilva
EDITED BY MODERATOR: Moved to the Parts and Features space. You have now made 4 posts, all in the General space. Please post to the appropriate space when one exists so your posts are properly categorized and so people following the different spaces get notifications of your posts.
just sketch a circle on the front plane and make an extrusion. Same on the right plane but this time extrude in both direction. Then you add the fillet on the sharp edge. At least you will use the shell feature to make it hollow. Add all 3 round faces to the list box of faces to extrude. Done.
If you want to use this tee later with the routing add in, than you have to create all 3 arms separately.
