I need to send out a part to a shop which needs to be made and it contains a few holes, threaded and non threaded holes. I have used the hole wizard in the 3D model to show the holes. When I create a hole table table in the drawing, it doesn't state which holes need to be threaded. Am I right to assume that by using the hole wizard, the hole will be only be machined without threads. I know how to create threads but I have no idea how to send it out to the shop so they don't get annoyed and over quote me or something similar to that effect. Can I create a drawing and add notes and arrows on which hole needs to have threads?
Also another question: If I want to use M2.5 screw, what's the hole size I need to make? I saw a chart on google but it said the clearance level have to be 2.9 which I quit didn't get. Or is that something I dont need to worry about as long as I state this hole is M2.5?
Need help here guys.. recent grad.
Babar Firasat ,
It really depends on how you want to send information to the shop floor.
If you're only sending your model, which I do not recommend, any threaded holes you made with the hole wizard will be labeled as threaded in the feature tree unless you change the feature name.
I strongly recommend you send a drawing, either a hard copy or a .pdf, to the shop floor with all threaded holes and non threaded holes clearly called out. You don't have to call out the drilled hole size on threaded holes the thread size and depth are sufficient.
