I convert a SolidWorks file to an .smg then in Composer I want to "save as" a Technical Illustration .svg .
Composer starts the process then crashes. The SW file is from an outside vendor.
My team is having the same issue on several machines and several files since the upgrade to 2019 (SP03).
Enrico Kliesch are you saying it could be a single part in an assembly that is causing the issue on export?
we have the same issue. At the moment we try to figure out which part is producing the Problem.
