Hi all,
I have un little problem with the document manager api : GetExternalFeatureReferences2
let me explain :
I want to get the BOM for an assembly in several configuration, with component name and referenced configuration.
For a simple exemple I have done an assembly with 2 configs and 2 parts (with 2 configs each) it's look like this :
Assy config 1 :
Part 1 - Config 1
Part 2 - Config 1
Assy config 2 :
Part 1 - Config 2
Part 2 - Config 2
Part 2 - Config 2 (second occurrence of part 2 is suppressed in Assy config 1)
And that's how my code works :
the "main" sub ; (how can I format my code in a forum post?)
Sub GetRefWConfigs()
DTGView_Tbl.Rows.Clear()
Dim AsmName As String = IO.Path.GetFileName(TBox_Asm.Text) 'I get the assy path from an userform
swDoc = swDocMgr.GetDocument(TBox_Asm.Text, 2, False, OpenErr) 'get the assy doc
configMgr = swDoc.ConfigurationManager
Dim vConfAsm As Object
Dim conf As Object
vConfAsm = configMgr.GetConfigurationNames2(SwConfsResult) 'get all config
For Each conf In vConfAsm 'loop on all assy configurations
DTGView_Tbl.Rows.Add({True, AsmName, IO.Path.GetDirectoryName(TBox_Asm.Text),
AsmName, AsmName, conf, "", 0}) 'puttin' the result in a datagridview
TraverseCpt(swDoc, 1, conf) 'call the components
Next
swDoc.Save()
swDoc.CloseDoc()
the "Traverse component" sub :
Sub TraverseCpt(ByVal swDoc As SolidWorks.Interop.swdocumentmgr.SwDMDocument18, ByVal Level As Integer, ByVal AssyConfig As String)
Dim dmSearchOpt As SolidWorks.Interop.swdocumentmgr.SwDMSearchOption
Dim ExtRefs() As String
Dim ExtRefsconfig() As String
Dim dmExtRefOption As SolidWorks.Interop.swdocumentmgr.SwDMExternalReferenceOption2
Dim numExtRefs As Integer
'setting up search options maybe this is not good
dmExtRefOption = swDocMgr.GetExternalReferenceOptionObject2
dmSearchOpt = swDocMgr.GetSearchOptionObject()
dmSearchOpt.SearchFilters = (SolidWorks.Interop.swdocumentmgr.SwDmSearchFilters.SwDmSearchExternalReference)
dmExtRefOption.Configuration = AssyConfig 'assembly config
dmExtRefOption.NeedSuppress = False
dmExtRefOption.SearchOption = dmSearchOpt
numExtRefs = swDoc.GetExternalFeatureReferences2(dmExtRefOption)
ExtRefs = dmExtRefOption.ExternalReferences
ExtRefsconfig = dmExtRefOption.ReferencedConfigurations
For i = 0 To ExtRefs.Length - 1 'loop on component
DTGView_Tbl.Rows.Add({True, IO.Path.GetFileName(ExtRefs(i)),
IO.Path.GetDirectoryName(ExtRefs(i)), IO.Path.GetFileName(ExtRefs(i)),
IO.Path.GetFileName(ExtRefs(i)), ExtRefsconfig(i), "", 0})
Next
dmSearchOpt = Nothing
dmExtRefOption = Nothing
ExtRefs = Nothing
And that's what I got at the end (I put the datas in a datagridview) :
the components loop seems only to take un account the last active configuration.
How can I use GetExternalFeatureReferences2 with assembly configuration (or tell GetDocument to get a specific config??)
Do you guys have an idea ?
and thank to all how have read all that !
Some reason you are looking for external references instead of components?
http://swlclb-569354389.us-east-1.elb.amazonaws.com/2018/English/api/swdocmgrapi/SolidWorks.Interop.swdocumentmgr~SolidWorks.Interop.swdocumentmgr.ISwDMConfiguration2~GetComponents.html?verRedirect=1
