Everything works great, except the check in. It checks in, but the reverts back to the old file. I know this because if I rem-out the CheckIn sub, the file dates are correct.
This is driving me crazy!!! I've tried IEdmFile5 and IEdmFolder5 as well, no difference.
Thanks for any help you can provide.
I have this blurb of code:
If IsToolbox(AF(c)) = False Then
' Open Model in Solidworks
SWAPP = CreateObject("Sldworks.Application")
SWAPP.Visible = True
' Checkout Model
CheckOut(AF(c))
' Open and update Model
If System.IO.Path.GetExtension(AF(c)).ToUpper = ".SLDASM" Then
swModel = SWAPP.OpenDoc6(AF(c), swDocumentTypes_e.swDocASSEMBLY, 1, "", fileerror, filewarning)
ElseIf System.IO.Path.GetExtension(AF(c)).ToUpper = ".SLDPRT" Then
swModel = SWAPP.OpenDoc6(AF(c), swDocumentTypes_e.swDocPART, 1, "", fileerror, filewarning)
swModel.ShowNamedView2("*Isometric", 7)
swModel.ViewZoomtofit2()
status = swModel.ForceRebuild3(False)
System.Threading.Thread.Sleep(10000) ' Manual Pause
System.Threading.Thread.Sleep(3000) ' Manual Pause
status = swModel.Save3(swSaveAsOptions_e.swSaveAsOptions_Silent, fileerror, filewarning)
SWAPP.CloseDoc(swModel.GetTitle)
' Checkin Model
CheckIn(AF(c))
Private Sub CheckOut(fPath As String) ' fPath = C:\Sackett-Waconia\Migration Workgroup\Workgroup\TOWER\Tower 150 Ton\17-2651 Prinsburg, MN\E7080099.sldasm, or whatever is called
Dim eFile12 As IEdmFile12 = VAULT.GetFileFromPath(fPath)
Dim eFolder9 As IEdmFolder9
Dim ePos5 As IEdmPos5 = eFile12.GetFirstFolderPosition
eFolder9 = eFile12.GetNextFolder(ePos5)
eFile12.GetFileCopy(0, 0, eFolder9.ID, EdmGetFlag.EdmGet_Simple)
If eFile12.IsLocked = False Then
eFile12.LockFile(eFolder9.ID, Me.Handle.ToInt32())
Private Sub CheckIn(fPath As String) ' fPath = C:\Sackett-Waconia\Migration Workgroup\Workgroup\TOWER\Tower 150 Ton\17-2651 Prinsburg, MN\E7080099.sldasm, or whatever is called
If eFile12.IsLocked = True Then
eFile12.UnlockFile(eFolder9.ID, Me.Handle.ToInt32())
Here lieth the problem:
