BABrian Austin18/06/2019
This VBA macro works to set a dimension to basic
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set Part = swApp.ActiveDoc
'EditDimensionProperties2(TolType, TolMax, TolMin, TolMaxFit, TolMinFit, UseDocPrec, Precision, ArrowsIn, UseDocArrows, Arrow1, Arrow2, PrefixText, SuffixText, ShowValue, CalloutText1, CalloutText2, CenterText)
boolstatus = Part.EditDimensionProperties2(1, 0, 0, "", "", True, 9, 2, True, 12, 12, "", "", True, "", "", False)
Part.ClearSelection2 True
However, you can see that it also sets the arrows and the suffix text for the selected dimension.
I need to read these values first from the SELECTED dimension, so I can insert the existing values into the "boolstatus" command.
Once I learn how to read all of the parameters for the command, I can then alter only one.
I have seen many web sites on how to loop thru all dimensions in a drawing (see below), but not the selected dimension.
Brian
Option Explicit
Dim swView As SldWorks.View
Dim swDispDim As SldWorks.DisplayDimension
Dim swDim As SldWorks.Dimension
Dim swAnn As SldWorks.Annotation
Set swModel = swApp.ActiveDoc
Set swDraw = swModel
Debug.Print "File = " & swModel.GetPathName
Set swView = swDraw.GetFirstView
Do While Not swView Is Nothing
Debug.Print " View = " & swView.Name
Set swDispDim = swView.GetFirstDisplayDimension5
Do While Not swDispDim Is Nothing
Set swAnn = swDispDim.GetAnnotation
Set swDim = swDispDim.GetDimension
Debug.Print " ------------------------------------"
Debug.Print " AnnName = " & swAnn.GetName
Debug.Print " DimFullName = " & swDim.FullName
Debug.Print " DimName = " & swDim.Name
Debug.Print " swDimensionParamType_e type = " & swDim.GetType
Debug.Print " DrivenState = " & swDim.DrivenState
Debug.Print " ReadOnly = " & swDim.ReadOnly
Debug.Print " Value = " & swDim.GetSystemValue2("")
Debug.Print ""
Debug.Print " Arrowside = " & swDispDim.ArrowSide
Debug.Print " TextAll = " & swDispDim.GetText(swDimensionTextAll)
Debug.Print " TextPrefix = " & swDispDim.GetText(swDimensionTextPrefix)
Debug.Print " TextSuffix = " & swDispDim.GetText(swDimensionTextSuffix)
Debug.Print " CalloutAbove = " & swDispDim.GetText(swDimensionTextCalloutAbove)
Debug.Print " CalloutBelow = " & swDispDim.GetText(swDimensionTextCalloutBelow)
Set swDispDim = swDispDim.GetNext3
Loop
Set swView = swView.GetNextView
Loop
