Spline: Is there a way to change the endpoints of spline to another point?
Question asked by Aaron Zheng on Jun 18, 2019
Latest reply on Jun 18, 2019 by Aaron Zheng
Recently, I have created a closed contour consisting of two parallel lines joined by a spline, as shown here, similar to my last question:
 Right now, the spline endpoints are coincident with the lines. The sketch is closed by lines on the top and bottom, and splines on the right and left. However, I need parts of the spline to be a line for a little while on both the right and left, such that I can extrude the part and include motor holes and make it easier to insert screws and holes, as a straight body will be the most ideal for screws.
I deleted the coincident relation and all possible distance relations that could be constraining the endpoint of my spline, and I tried to move it. However,  when I try to move the spline point off the line, I still cannot do it.
In this situation, how can I effectively move the endpoints of the spline to other points in the sketch?
Thank you,
