Victor L
Workaround needed
Discussion created by Victor L on Apr 8, 2009
Hi.
I have a model that "flies" along Y-axis. The model is oriented so that I input the negative speed. When I calculate Y-component of force, it always in negative range. I used to deal with this problem (SW2008) by adding one more coordinate system with Y-axis opposite to default Y-axis.
Now (SW2009SP2.1) try this trick and it doesn't work. I add two Y-component of force. One for global coordinate system and one one for my coordinate system. The results are absolutely identical (i.e. negative).
Any solutions on this?
