I made a sketch in solidworks which I saved as a DXF because DXF is what my Laser cutter accepts
As well as loading it in my laser I sometimes improt it into inkscape to set the colours of the lines to Red and Blue
My laser knows to engrave blue lines and cut red ones
Every thing is fine unless I use a bezier curve in the sketch and then if I load it into the laser or into inkscape , it adds
an extra line , a straight line between the two ends of the bezier curve I cant of course leave this line in as the laser would treat it as a cut line . In inkscape I can select the whole drawing and do ungroup which seperates all the lines but sadly
it wont ungroup the extra line from the bezier curve so I cant delete it , Does anyone know a way around this ?
I will try to add a picture pointing to the unwanted lines that solidworks seems to like adding
I indicated the nuisance lines with red pointers
Do you have the latest version (0.33) of K40? I just looked at the source code and the problem has been fixed.
