So I gather the PDFCreator that installs with SWE and is the only option when you select Export To PDF. But the default paper sizes available to me in that are not sufficient. I need 11x17 (ledger) and don't have it. Anybody know how to add additional paper sizes or change the standard PDF output program or anything else that would enable me to print PDFs that look like the paper versions I print? As it stands I am getting ugly offsets and margins in the other paper sizes.
Okay I found a solution to this myself. What I did was install PDFCreator myself the full software which has tons of paper sizes included. I had to install it under a different name for the printer, then I deleted the PDFCreator printer I had and renamed the printer in the PDFCreator software to PDFCreator. SWE is looking for that named printer and is fine with it being a upgrade one.
