A surface model has been created, enclosed, knitted and thickened. Big fillet for the part creates a surface like this. How to fix it? File is 2016v
(edit, not awake yet..)
Maha, ..btw, the reason that is happening is because you have VOR off. (verification on rebuild)
..the MROC (min radius of curvature) is R23... your R30 is well beyond so, with VOR off, the surface is folding/inverting (thicken).
..and for the luck of it,. ok,.. the R30 seems to work fine if you roll before the thicken? kewl!
U r using sw2016, not sure if you can open and view the file
You need to add inside fillet first (28mm)
or you can create a solid when knitting the surfaces, add fillet and shell it
