Hi to all,
I've set the standard length to 6000 mm, but for some reason (stock warehouse), I changed to 4000 mm, but the number of pipes didn't update.
How can resolve it ?
And if I uncheck this options, pipes still remain two.
I just checked it out in 2009 SP03, it worked fine for me. You will need to change the value on the route segment properties, (edit route, select the pipe segment, Route segment properties -> Change the length, OK).
It won't change anything if you just change it in the default route properties.
If in doubt, delete all of the pipe parts, edit route exit to recreate them, but this shouldn't be necessary.
Let me know how you get on.
Andy
