I am having an odd issue with an offset section view in SW 2019. The cutting line for section A-A has a little jog in it and the resulting section view is adding the distance of the jog into the section. I have done this in SW 2018 but have since upgraded. I'm thinking there may be a setting in the options somewhere? The third pic I am attaching is the result that was done in Solid edge a few years ago. the .135 dimension I am getting should only be .020-.025 (which it is in the solid edge version
I hope I am explaining this clearly.
Edit the sketch line for Section A-A, change the horizontal line segment to a construction line.
Otherwise, SolidWorks adds the length of non-construction lines that are perpendicular to the section and stretches the view.
