Hello, I'm sure this is a rookie question with a quick answer. I am trying to design a case to enclose a motor for which I have a .stl file. What I'd like to do is import the motor file and build up the case dimensions using the motor as a reference, then hide/suppress it when completed. However when I hide the motor anything referencing it also gets hidden. What is the right way to do this?
Hello Matt,...I'd suggest you use '''Insert Part".at the beginning of the crates feature tree..and at the end of the feature tree use "Remove Body".
Otherwise,..do not apply any relationships to the STL.
