I have a new part that is not fitting the Zoom Fit window it's all off to one side with lots of blank space around. I think it may be something else in the part file I can not see anything or select it
Been looking for points or graphic images or lines not on view
But using the Zoom all command the main part is off to one side looks as if something is giving a much total larger area than required making it hard to move the main item I am interested and when exporting to 3D pdf file the part is very small and off to one side. and not a lot of good. This all workes with other Solidworks part Files
Any ideas?
Andrew
There are a few images in the file I just can't find anything does not work with a selection window off to one side of the part Image below is part as viewed. I can't see any other items in the view screen
The Plan is to make a 3D file to produce some cristal cut 3D trophies. Don't know if there is anything wrong with the file that will stop them from doing this
There is either a hidden sketch component or a hidden sketch dimension.. How to find which one.... Take the row back bar up one feature and hit "F" (for zoom to screen), if it doesn't zoom in then row back another till you find which sketch is giving you the issue..
