I would like determine the buckling load factor for telescopic hydraulic cylinder.
Question asked by Shreeshial Biradar on May 31, 2019
Latest reply on May 31, 2019 by Dan Golthing
I would like determine the buckling load factor for telescopic hydraulic cylinder.The cylinder is 15 meters long in its extended condition and the diameter is around 175 mm.Do I need to do the non linear buckling analysis for these dimensions?. I have done the linear buckling analysis for this problem and the buckling factor i got is less than 1 whir i was not expecting from the analysis. If I run the same simulation setup with non linear analysis with arc length method (Nonlinear Buckling),I am getting load factor of 7. Now My question is which one to to be considered to determine the buckling load factor of this cylinder??.
nonlinear buckling buckling
EDITED BY MODERATOR: Please use a brief title related to your post, not "Hi". That way, users can tell the subject of your post from the listings instead of clicking into it. I have used your first sentence, which is appropriate.
