I created a new BOM with different columns than the example BOM that someone previously created here. When I go to the Bill Of Material tab when clicking on the assembly file in PDM, the previous BOM choice is the default. Is there a way to set the other BOM created to show by default instead of having to do the drop down and selecting the new BOM every time?
In the attached picture, I want LAN BOM to be the default BOM that displays, not Example BOM. Renaming it to come before Example BOM in PDM Administrator doesn't change anything. I know I could just delete the Example BOM but I don't know if another location is using it.
Using Solidworks 2017 & PDM Professional 2017
The .cex file is correct. To import, click File...Open and select the CEX file. It will open a dialog listing everything that was exported. Just drag the BOM you deleted to the 'Bills Of Materials' node in the admin tool. That's it.
