in my part I made configurations and I set configuration specific equations. The problem is that I opened file after adding new configuration and equations show that the variable is set for all equations (and that's not true because it will still be different value in different configurations).
However if I now change set to this configuration only it will reset that variable for all configurations. So I basically can't touch this or it will reset values on all configurations.
(I think this happened when I added new configuration. So basically adding new configuration kinda messes up this.)
Is there workaround to this?
Edit:
I've been playing around a bit and I think it's a bug.
Add new configuration doesn't destroy this however copy/paste existing configuration does.
