My current box has a Quadro M-5000 GPU. It performs well but you can never have too much power and I need faster rendering results. https://images.nvidia.com/content/quadro/product-literature/data-sheets/12488_NV_DS_Quadro_M5000_Aug11_US_NV_HR.pdf
I was going to purchase a Quadro RTX 4000 to add to the box and then Vis would use both the M5000 and RTX 4000.
https://www.nvidia.com/en-us/design-visualization/quadro/rtx-4000/
But the RTX is an 8gb card and I can buy the GeForece 2080 TI (gaming version of the RTX 4000) for about the same price and its an 11gb card. https://www.nvidia.com/en-us/geforce/graphics-cards/rtx-2080-ti/
I think I can have both the M5000 and the 2080TI in the same box, specify SW uses the M5000 (its a certified card) and Visualize use the 2080 as its Primary card (so I have the 11gb advantage) and the M5000 as a secondary card (so I can use the cuda cores from the M5000)? I'm not sure of this however and before I drop a cool $1K I want to be sure this is possible. Does anyone know if this can be done or is doing this now? If so is it easy to setup?
Never try that before.
Borrow a GeForce/Quadro and test.
I'm not sure if you'll gain anything.
Unless you can run Visualize while using SW.
