Just wanted to know if there was a way to set font/text in composer (bom) to Upercase?
I don't know if you can do this with default fonts. You can try to use all caps fonts. From a quick google search i found this list:
https://www.designer-daily.com/15-gorgeous-free-all-caps-fonts-48867
Cheers,
Ali Sinan
there is no function therefor in Composer.
But you can use CAPS LOCK on your keyboard instead… ;-)
Even the option in SolidWorks to use all caps does not function as one would expect. Best thing is to try and use all caps if that is what you want and wait to see if they can get more to work right.
Cheers,
Ali Sinan
