I have a weldment that has a sheet metal part in it. If I place the base view and use the Flat pattern view everything appears properly. However if I project a view from a base view and pick the flat pattern configuration a phantom view of the entire weldment shows up. Any idea what might be causing this?
Flat Pattern in a base view
Flat Pattern configuration in a projected view. Projected from middle view.
With multiples bodies, try using a Model View:
Kevin
