I want to build these 4 sided panels which have a base that does not have 90 degree corners. The base is irregular. I need a flange on each edge but, one is a 135 degree bend. The other three are 90 degree bends. What is the best way to do this? When I do this I get a really messed up corner detail in the flat. I need to do this about 40 times for this one assembly.
If you can, please add some images of what you're trying to do and what you've tried so far.
Upload your files, too, would help the replies: How can I attach a file to a forum post?
That typed, is this what you're looking to do?
The top/left, upper/right and lower/right flanges are 90°.
The other is 135°.
All flanges are the same height up from the base.
This is the base flange sketch:
This is the flat pattern:
Please post with what you're looking for and what you've tried to do.
Kevin
