I just received Solidworks Premium. I have been wanting to use Solidworks toolbox but, It just will not work. Whenever I try to add a bearing into my design, It will not load and It just says "Older version file. The file will be converted when saved." I am very confused and I need some help. Thank you
Before Pressing the Checkmark
After pressing the Checkmark
EDITED BY MODERATOR: Moved to the Toolbox space. Please post to the appropriate space when one exists.
Older version file simply means that the version of SWX that that file was last saved in is older than the current version you are in. Unless you need to use that older version of SWX there is absolutely nothing wrong with this warning and you can go ahead and use the bearing.
