KCKaijiun Cheang15/05/2019
I got a macro that works before. This macro is used to add an BOM into drawing. When i run it through driveworks, it is not working. It shows (A serious error occurred on open macro file. The system could be in an unstable state now.).
But i have no problem run it with drawing opened.
Then i recalled it could be the newly updated solidworks 2019 that i am running not long ago. But i don't have any knowledge to update the command to the latest library. Can anyone tell which one has been obselete? Or any problem that i am not aware of?
Thanks.
Option Explicit
Dim swFeatMgr As SldWorks.FeatureManager
Dim swView As SldWorks.View
Dim swBomAnn As BomTableAnnotation
Dim swBomFeat As SldWorks.BomFeature
Dim anchorType As Long
Dim bomType As Long
Dim configuration As String
Dim tableTemplate As String
Dim Names As Variant
Dim visible As Variant
Dim boolStatus As Boolean
Dim swSheet As SldWorks.Sheet
Sub Main()
Set swModel = swApp.ActiveDoc
Set swFeatMgr = swModel.FeatureManager
Set swDraw = swModel
swModel.ActivateSheet "Sheet1"
'Select View
swModel.ClearSelection2 True
Set swView = swDraw.GetCurrentSheet.GetViews()(0)
'Insert BOM Table
anchorType = SwConst.swBOMConfigurationAnchorType_e.swBOMConfigurationAnchor_TopRight
bomType = SwConst.swBomType_e.swBomType_TopLevelOnly
configuration = "CLOSED-OFFSET BIFOLD" '"Default"
tableTemplate = "P:\Data\Engineering\SOLIDWORKS\TEMPLATE\AM BOM TABLE.sldbomtbt" '"C:\KMI-Vault\Admin Files\SW - Templates\TABLES\kTable.sldbomtbt"
boolStatus = swModel.Extension.SetUserPreferenceToggle(swUserPreferenceToggle_e.swOneConfigOnlyTopLevelBom, 0, True)
Set swBomAnn = swView.InsertBomTable4(True, 0, 0, anchorType, bomType, configuration, tableTemplate, False, 2, False)
Set swBomFeat = swBomAnn.BomFeature
Names = swBomFeat.GetConfigurations(False, visible)
visible(0) = True
boolStatus = swBomFeat.SetConfigurations(True, visible, Names)
swFeatMgr.UpdateFeatureTree
